- Nov 12, 2014
- 169
I bought a Harbor freight tool grinder 46727 and other than one wheel, its like new. The PO bought it new and said he only used it a couple times to sharpen lawn mower blade and been setting unused for several years. It has the original green wheels and as stated above one looks unused and the other has some groves in the side. I plan to use this for sharpening HSS lathe bits and also I plan to make a Harold Hall jig for sharpening HSS end mills. I searched many forums for an answer to which wheels but most are asking about carbide grinding and not grit.
What wheels/grit would you recommend for HSS? Hopefully I could use the original wheel for roughing. But, I’m not opposed to replacing both if necessary. I am pretty certain they are 80 grit silicon carbide. But how about a finishing wheel? This grinder has a speed of 3450 RPM.
