- May 28, 2011
- 17
Always checking the tool height on the QCTH that I had . The old pinch the ruler , dead center in the tailstock , and other methods were used , but most of the time it left that little tit on the facing op . Grr ! Found some stuff in the scrap box and came up w/ this design and it seems to have solved 99% of the problem . The base is a cut-off of 1" diam. Al with a neodymium Super Glued flush w/ the bottom . A 3/8" adjustment rod , some knurled adjustment nuts and a 1/4" tapered pointer in a 3/8" threaded Al block . Nothing fancy . After I got it made and set by facing a piece in the lathe , found that almost all the tool holders were off . Some of them quite a bit.
The neodymium magnets are super powerful for their size and find a lot of uses in the shop . Got a bunch in different sizes for projects .
Degree wheel w/ pointer .
