David,
First I applaud you for not forcing the suspected worm mechanism. IMHO, forcing it would almost guaranteed catastrophic damage.
I suspect that the two grub screws are a type of "Scotch key" which both prevent rotation of the worm bushing and retain it in the housing.
My bet is, if you remove those two grub screws, turning the hex head (in the correct direction) will lift the worm and bushing right out of the housing.
As for the locking bolt: it makes sense to me that it would be a split cotter. Can you see the end opposite the bolt head or is it all in a blind hole?
If the opposite end is visible (not a blind hole) remove the bolt and both parts of the split cotter. If it's a blind hole, I'd keep tapping the lower part of the split cotter (nut) down to be certain it's disengaged. Then remove the bolt and fish out the upper part of the split cotter. The next step is to apply a liberal amount of penetrating oil and let soak for a day or two.
In case you're not familiar with the term "split cotter" THIS should clarify it. I Googled "split cotter" but found only cotter pins (split pins). No help in Wikipedia either. I must have weak Google fu today.
In your picture I see a hole that looks like it's directly over the axis we're trying to free up. What's the hole for? Possibly a dog point grub screw (running in a groove on the shaft) to retain the shaft (but BOZO has over-tightened it)? What do you see when you look in the hole? Is the hole through to the rotating shaft? Fill the hole with penetrating oil???
If you do all of the above and it won't free up after a day or two soak, I would warm the housing with a hot air gun to 200-300F and add more penetrating oil. Repeat the heat/oil cycle a few times a day for a few days.
Good luck.
Edited for spelling
Good luck.
Edited for spelling
