Hi Guys,
I bought a tool and cutter grinder recently and I’m just trying to figure out how everything works and what tooling / fixtures I need to go with it.
It has cleaned up great and most things slide and glide very nicely.
As best I can figure out it is a called a Chevalier End Mill Grinder Model FCG-610 made in Taiwan.
I'm trying to swivel the head on the horizontal axis. That is along the scale you can see in the second image.
It would appear that bolt you can see at the back of centre would be the lock bolt.
I can undo that and completely remove it.
It would appear that the bolt at the front is some kind of worm gear that should rotate the head along that axis.
The worm botl turns freely about 1/4 of a turn in total but the angle does not move at all. Not even a wiggle.
I'm assuming this movement is backlash in the worm.
I couldn't find a manual but I did find a sales brochure (attached).
It lists that front hex as "2. Vertical adjustment of wheel head (including wheel head fixing)"
Which sounds to me like it lost something in the translation
The vertical adjustment is the big hand wheel on top and the lock is the Lever on the left.
Is there anyone here that has used one of these and knows how it is supposed to work.
If it is simply stuck I'm open to ideas on how to unstick it.
Thanks in advance
David
Thanks in advance
David
