- Feb 1, 2015
- 9,947
I am going to buck the trend here and say to look for a smaller lathe. Unless you are looking at making earth movers, you in all likelihood will never need the 16 x 60. While much can be said for the rigidity of a large machine, you will most likely inherit a host of issues with an older machine. It is unlikely that an industrial machine going for a "good price" is going to be in anytrhing close to pristine condition.
On the other hand, starting out with a smaller machine, you can take on a large variety of projects, learning the art as you go. As you build up your skill level and you feel a need to for more capacity, you can look for that larger machine. A small lathe needn't be very expensive and if you take care of it, you should be able to recover the better part of your investment.
There is also an issue of personal safety. A large machine with hefty motor can be a dangerous item. If you misstep, it will just as easily rip your arm off as it make that facing cut.A smaller lathe running a fractional horsepower motor can be dangerous too but you are not likely to get wound up in the chuck.
