- Dec 3, 2017
- 2,184
If you don’t mention it, it doesn’t need a name. But if you must mention it, just call it an auxiliary saddle rigidizing apparatus.The reason for my question being is that I struggle to know what to call the extra assembly I've added to my mini lathe that bolts to the underside of the saddle, in the middle and uses the underside of the bed, in between the ways, to hold the saddle down for extra rigidity]
It's weird, for such a critical part, I mean it holds the saddle in place against lifting forces, it feels like it should have a more, oh, I don't know, distinctive name.
The trick with this sort of thing is to saturate the web with your chosen nomenclature. Insist on its inherent rightness, and aggressively challenge alternative definitions with focused propaganda that delegitimizes alternative language. Find acolytes, who will amplify your message independently of your guidance, with even more aggressive and targeted niche markets. Make people who don’t use your word afraid, if possible. Try to twist everything they say into an ideological argument, and absolutely never give an inch on your stance. Best of luck!
