Contrary to urban myth, NASA did use the metric system for the Apollo Moon landings. SI units were used for arguably the most critical part of the missions – the calculations that were carried out by the Lunar Module’s onboard Apollo Guidance Computer (AGC) during the computer-controlled phases of the spacecraft’s descent to the surface of the Moon, and for the journey of the Ascent stage of the craft during its return to lunar orbit, where it would rendezvous with the Command and Service Module (CSM).There are 2 types of countries, those that use the metric system and those that have been to the moon........
Have a reference for this? Would make for an interesting read. When I did radar work, I did everything in SI units as it was far easier! If I had to convert it was either at the very beginning, or at the end. In the middle was the path to madness!Contrary to urban myth, NASA did use the metric system for the Apollo Moon landings. SI units were used for arguably the most critical part of the missions – the calculations that were carried out by the Lunar Module’s onboard Apollo Guidance Computer (AGC) during the computer-controlled phases of the spacecraft’s descent to the surface of the Moon, and for the journey of the Ascent stage of the craft during its return to lunar orbit, where it would rendezvous with the Command and Service Module (CSM).
The computer display readouts were in units of feet, feet per second, and nautical miles – units that the Apollo astronauts, who had mostly trained as jet pilots, would have been accustomed to using. Internally, however, the computer’s software used SI units for all powered-flight navigation and guidance calculations, and values such as altitude and altitude rate were only converted to imperial units when they needed to be shown on the computer’s display.
My dad ran the test lab at United Technologies for the Saturn V project. Can’t ask him anymore but I have his slide rule.Urban myth it is then. Sounds good though, I'll keep using it.
My uncle did design work on the big Saturn rocket, I'll ask him.
