- Oct 21, 2017
- 504
CNC is fun, there's no doubt about that, On the other hand, Its really great for making 5,000 whatzits. If you're a hobbyist, you don't need that many.
I used to think like this until I discovered that CNC is excellent for onesy-twosey parts with compound curves and 3D features which would be impossible with manual equipment or would take so many set-ups with custom fixtures that they wouldn't be worth doing.
This is a .20 cal rotary magazine I made for a target air pistol, the central mag advance ratchet feature has areas where the cutter must be less than 0.8mm diameter
Even with a rotary table, multiple custom fixtures and a high speed spindle I suspect it would be a bit of a pig to machine with 0.6mm or 0.7mm end mills
