- Apr 23, 2016
- 99
Learning things every day as I start using my Craftsman 12x36 more and more.
I had purchased some 1 1/4" A36 Hot Rolled round bar for a drill jig project and soon found out that this isn't the easiest material to work with on the lathe. Problem being the hard outer surface of the stock plays hell with my cutting bits.
I am wanting to smooth the outer surface of the stock, and want to keep as much of the material as possible... not a critical diameter... more for esthetics. I mainly use the 3/8" indexable carbide tools but have tried 3/8" HSS ground to a little larger tip radius as well as the sharp tip. I've tried various lathe speeds and feed rates, using cutting fluid and not. What I end up with is dulling the cutter within 30 minutes and having to either re-grind the HSS or changing the carbide inserts. I have several pieces to make so it's getting frustrating to have so much down time
Last night I ordered some Cold Rolled TGP that should eliminate the problem, I hope... but I have enough of the hot rolled material that I would still like to use it up.
Can I get some tips and/or suggestions on machine setup and/or cutting techniques that will improve the life of my cutting tools?
