Ok continuing....
I got the parts done and shipped yesterday. All went well, but drilling & tapping the holes was a bit stressful.
The following are all staged pictures showing the setup. Staged because I didn't get any pictures of the actual operations, and I can't show the parts anyway due to NDAs. All of the operations were done manually by feel and sound, and yes you can actually feel what's happening even with a 25 lb quill and a tiny tool.
So first ''drill'' a starter hole with a 0.032 endmill. The only 1/8 dia center drill I have is broken on both ends, so grab the next best thing. This nicely mills off the little nub that's left from the parting operation, and really does give a straight hole. I actually centered the tool by eye (and 10x magnification) using a pin that was just slightly larger than the endmill. There was no other way to do it because of the runout in the bit and not knowing exactly where the center of the air spindle is relative to the machine spindle centerline. The air spindle goes in a 5/8 endmill holder, and the air line goes down through the spindle hole where a drawbar would normally be. My machine has a quick change spindle so no draw bar.
And the air supply.
So first operation, 0.032 end mill, solid carbide
Then drill with a 1mm drill bit. Solid carbide circuit board drill. I one part I had to drill 7mm deep, 7 diameters, that was nerve wracking. The other part was only about 4mm deep, so not so bad. The good news is that the torque of the air spindle was low enough to stall the spindle before snapping the drill bit, built in torque limiting.
Then the setup for tapping. For this operation I used my sensitive drill chuck and turned the spindle by hand.
That is a 1/8'' pin in the chuck, that tap is tiny. M1.2x0.25
I managed to get through all 6 parts without breaking a drill bit or a tap. I got very lucky, because I did not have time to make more parts. I beat the shipping deadline by about 7 minutes, and that required a trip to the UPS air terminal at the airport. These parts had to be in the hands of the customer today, UPS came through for me.
For those of you who have not seen a sensitive drill chuck, the inner shank slides up & down in the main shank and is driven by a key. The hand ring has a bearing in the center and is free to turn, this is how you control the down pressure. A great device for drilling & tapping small holes. I think the chuck capacity is 3/16''
So the next order of business was to mill the three 0.031 slots around the outside of one of the parts. I was going to do it with the spindex on the mill, but because of the runout in the air spindle I wan not able to do so. The smallest endmill I have is 0.031 and with the 0.003 runout the slots would have been oversize.
So on to plan ''B''. I'll use the shaper lathe
The slots are only 0.006 deep.
Here is the tool bit
So first align a slot in the collet with the tool bit, luckily the tool bit and the collet slots are about the same size.
Then become a shaper and go 0.006 deep. About 0.001 per pass. Then rotate to the next position and repeat.
So today, back to some kind of normal work. Went to a customer and fixed their circuit board soldering oven, had a bit of a cooling problem at the cold end of the conveyor.
Then back to some normal machine work with a nice big beefy 1/4'' ball end mill
This is a part of a swaging die for another customer, this one I can show.
Needs to me modified to better shape the swage.
And after machining. All the heights were the same and the center was too wide when I started. So narrowed the center part, and took 0.035 off of the outside rails. Should work well now. If it works OK, I'll build another and have it heat treated. I'll deliver this one in the morning.
Then this morning about 1000 lbs of aluminum was delivered. It needs to all be converted into chips. Gotta start on that tomorrow. And I'm supposed to be retired.
Pesky customers keep bothering me.
And speaking of tiny parts, I turned down a job yesterday. One of the features had a 6 hole pattern of 0.013'' holes. I would have taken it, but it had a drop dead ship date of Friday (today is Wednesday). Just not enough time to get tooling in and get it done.
