@Saxguy - what do you expect to use it for?
I recently was looking for one for awkward fixturing of a cylinder head for light machining & drilling. I needed to be able to tilt in 2 axis/planes with near vertical (75-ish degrees?), so for that sort of job an adjustable angle plate similar to what
@davidpbest posted was needed. The slots can give you that 2nd axis but there are also swivel adjustable angle plates...but reaaaaally expensive. I ideally wanted this though (looked a bit more beefy). Old and hard to find.
The hump style looks much more stout and generally larger options available. If <=45 degrees and/or expecting heavier machining: I'd think this type would be better suited. Just my 2c.
