I was thinking the same approach to this, lightning quick high amperage tacks.I'd turn it up to 200 amps, hold tungsten close and give it a quick on/off pulse just like a small tack. Be stronger than the rest of the pieces. Might have to come back and do another 180 degrees, depends on how it looks.
So, filler or not?I got to the rings today, I tried the 200 amp setting, it was to explosive, and I could not control the burn. Next I tried the 40 amp suggestion, and that was much more controllable. I chickened out on using a single ring, and added a 2nd for my piece of mind, not wanting to have a failure with one or more big tunas on the hauler line. When I trust my welding I'll start using a single ring. I need 6 joints to make up 1 rig so I have a few spares.
