Yes, Ted I know about balance but it was not clear as far as how to set the welder up properly for 30/70. The main difficulty I have isI also don't remember you saying what you had your balance control set at??? Maybe you did and I missed it. 30% positive and 70% negative is a good place to start. You want good cleaning action without burning your tungsten up. You said in your first post that the tungsten burned away, which might indicate the setting was way off and you were actually just "balling" you tungsten and it burned way back too far. If you don't know what I mean, check YouTube for "balling your tungsten". It's a practice where you intentionally burn the end of your tungsten back to form a sphere (ball) on the end of it. This is an old practice and most say not necessary with modern TIG welders. But, you need to have your balance set correctly to get good welds in aluminum (not used for other metals).
Ted
