- Dec 24, 2020
- 1,199
I have both 3/32 and 1/8 tungstens. Is there anything wrong with using the 1/8 for lighter work as long as I use the appropriately sized cup
for the job?
Generally speaking that's fine, but there are times when it won't terribly work well. For example, if you're trying to weld at low amperages you might get an inconsistent start or the arc wandering. That just shows you're not really running enough amperage for the tungsten diameter. If you put a really sharp point on the tungsten it will help minimize the arc wander in situations like that. It seems more noticeable if you're trying to do something like an edge weld on thinner material....the arc just won't focus on the edge like you need it to be. If you can't sharpen the point enough to get a consistent start and no arc wander, then it's just time to drop a tungsten size.
