I've been cutting some threads in the last week or so.....mainly just to get in practice to do them correctly.
Had a real usage today....making another stud for a QCTP. The thread is a 9/16-18. I'll talk about this one, but the problem seems to occur on any thread that I single point cut.
The fundamental problem- when I get to where I think the thread should be done, the thread is still too big. I always need to cut substantially deeper to make it mate with a nut.
For the 9/16-18 thread I started with a diameter of .557". Deliberately a bit under(-.005) the published major diameter of .562 so that the OD would not create any fitment problems. I ran the carbide thread cutter in on the diameter till it scratched the surface and entered the micrometer measured diameter into the DRO as a negative number (-.557"). Started cutting the thread.
The minor diameter is supposed to be .4958". I started trying to screw on the nut about .5". Then cut a bit more. And more. And more. No success at all until .490". And I was cutting about .001" at this point, so I'm pretty sure cutting forces were not pushing the part and the cutter apart. Even have tried doing some spring passes.
I'm sure that I did not have any backlash when I set the initial diameter and when I measure the cuts.
I was cutting at the 90 degree angle using the cross-slide (instead of doing the 29.5 degree cut with the compound.
The thread looks great. And it's a very good fit to the nut....tighter than using the same nut on the original AXA toolpost. If anything, the one I cut is more precise/tighter fit than the purchased stud.
I realize I need to be able to measure the minor diameter to do this right. At least that way I can see where my cuts are removing less than expected. So I guess I'll pick up some thread wires. But I'm wondering why measuring the initial diameter and then moving in the correct amount always seems to cut less than the numbers indicate that it should.
