I have recently purchased a Chin Hung lathe. It seems to be in pretty good condition but today whilst I was cleaning her up, I noticed the threading dial was loose to rotate. From the parts breakdown I am missing a washer but it appears there is no key way or spline or even a small pin to locate the correct alignment of the threading dial to the lead screw. The dial is reversible with numbers on both sides.
Looking in the manual i have just acquired, it doesn't mention setting up the dial indicator or mention this sort of issue in the troubleshooting. How would i go about setting the dial to be in the correct position with regards to the lead screw ?
