- Jan 22, 2014
- 160
Hi all,
I know this isn't exactly a machining question, but I'd like your point of view!
I make custom metal furniture, and more and more lately, we need very consistent threaded holes. I normally tap by hand, but some projects need more consistency than I can provide. I haven't been able to find machining classes yet, so I thought in the meantime, what would a welder do?
It has been suggested to me to check out threaded inserts, which I could just drop in the hole, weld, and sand the top smooth. Only problem is, the result is kinda ugly, not up to standards for fine furniture for us, and not even as accurate as I wanted. My first attempt was with standard weld nuts from McMaster-Carr that have a little flange. One way I tried was to just weld on the flange, which even if my welds weren't as sloppy, is a little too ugly for what we need. The other way I tried was to countersink the hole to fit the flange-- it ended up being a pain to do on my 1/8" thick steel and much less accurate than I wanted anyway. Didn't even both to sand it smooth all the way because apparently it was hard to keep the flange flush to the metal.
I think I'm going about this problem the wrong way, I need another eye to take a look.
Does anyone know of the kind of threaded insert that would be clean and quick? Do you think I should skip threaded inserts anyway and try threading on the drill press? I've been hesitant to try that out because our drill press is a little wonky- I don't think it is square to its bed and I've noticed the drill doesn't spin 100% centered and tends to slide sometimes while beginning the hole.
Also if anyone knows of basic machining classes in the NYC area, let me know. I try a lot of metalshop things on my own, but I honestly feel afraid to tackle the lathe on my own with Youtube University, but maybe it's not so tough to figure out? What do you think? Any advice is appreciated!
Thanks!
View attachment 234631 View attachment 234632 View attachment 234633 View attachment 234634
I would drill and tap instead of using inserts. The drill size can be for 60% of the thread. Most drill tap gauges give you 75% of thread which makes for harder tapping but stronger thread. For furniture the thread does not have to be at 75%, 60% is plenty strong.
Try a spotting drill or a center drill first before final drilling. This will aid greatly in starting the bore. You say the drill appears to turn off center? Do the 3 jaws come together . Install a machine drill in the chuck , look at the jaws. They should meet tight against the drill.
If not the chuck needs either repair or replacing. Square up the table to the quill. If this is not possible, make a table that can be shimmed to square. To check for square, set an engineers square along side the quill and sight it for parallel. Another way , take a wire coat hanger and bend two 90° bends. One end goes into the chuck, the other end will touch the table at a point away from the chuck. This depends on where you make the bend. Turn the chuck by hand 360°. The wire should touch the table at the same height in all directions. When it does the table is square to the quill. Usually the first method using a square is good enough for tapping.
When the table and chuck problems are dealt with you can save some times drilling using bullet drills. These drills make starting the hole and drilling thru in one shot. No need for starting drill or center drills. Probably plenty accurate for the work you do. I use spotting drills because I do not have but one bullet drill and too cheap to buy a set.
mike
