Thread Cutting Question
There is really no math involved, other than dividing the 46T gear by 2, which is 23T, then doubling the set figure by 2 to come up with the same number of TPI. So far as the basic principle, if you set the QC for the number of teeth on the QC box gear and replace it with a gear the number of threads desired, Bob's your uncle. Setting for other TPIs can multiply the number of possibilities of threads to be cut.
  • Like
Reactions: Kyo
I ran these through my gear chart calculator for the 1340GT. The only combination I could come up with would be a 46T input gear to the 120T, then mesh the same gear to a 32T and a gear selector setting of D1. The 32T is available from QMT if I recall was used to extend some of the metric ratios. The 46T you could have printed, there are a number of vendors that do that and if I recall the HM member [X]Outlaw has made some custom gears for the 1340GT.
Added Chart, this also would give an 11.5, 23 and the 46 TPI.
If you end up needing a 3-d printed gear (if I'm following correctly) let me know, I'd be happy to see if I could help.
DPaul7,
Sorry I had to finish mowing. The logic is thus: the ratio from the top (40T drive gear) to the bottom (40T driven gear) is 1:1. And you've confirmed that the large gear is an idler. So it is not a factor. Therefore all that is required is to find a ratio that works with an available Machine TPI setting that gives the desired result.
Formula used is (driven gear / drive gear) * Machine TPI = Result TPI
Example (normal setup) (40/40) * 48 = 48
This case: (46/40) * 40 = 46
or (23/40) * 80 = 46
Hope this helps.
Best Regards,
Bob
In what I read and have followed, the change gear was always used on the QC box input, not the stud gear, and it has always worked for me.
I use this program which gives me a lot of options. Put all variables into 'Generic Lathe' and save then find the .ini file and change thee name to the specific lathe. Only work is working out the gearbox ratios.
  • LGV1.2.zip
The method that I use does not need any of that stuff, and nothing of gearbox ratios, it's like falling off a log and would seem to work with most any lathe. For some reason, when I click on your attachment, nothing happens.
File LGV1 needs to be unzipped and then the .exe run to install the program on your computer. On the 1340GT both the input (stud gear) and output (QC input) needs to be changed for specific metric threads. This subject came up in the past specific with the 1340GT for some of the less common metric threads, and for that matter some of the odd ball imperial threads. There are different ways to determine the potential combinations or one can look at ratios for an existing thread and then work backwards on some divisible integer gear combination. The problem in some cases is the ratios work but the actual gear size or spacing/meshing does not.
Below is the metric gear chart for the 1340GT, a few of the change gears are special order from QMT like the 35T. David Best put together a metric thread setup chart with the default change gears and a few of the gaps for metric, these are filled with the 35T, other gears may also be available special order. I had been asked about the 11.5 pitch in the past, so it seems that it is possible with a 46T stud gear. Manual lathes are typically not designed for every possible thread, and mechanical threading gearboxes are always some compromise for universal threading. An ELS would solve that issue, I am actually surprised that lathe makers have not embraced that option, it would be less expensive and more durable then mechanical gearboxes. The higher end lathes tend to have universal gearboxes, so no change gears on say the ERL/RML/TRL lathes for imperial or metric, but none will not cut a 46 TPI.
  • PM 1340GT Gear Thread Chart with 40, 35, 32 30 change gears.pdf
  • PM1340 Metric Thread Setup.pdf
I do not have a 1340, but was curious as to what was being presented; my lathe is an older Leblond Regal, and the info I found for lathes with 4 TPI leadscrew does most any metric thread, that combined with the special thread instructions for imperial threads covers anything that I'd ever run into, including DP leads and much other esoteric threads. I have made a complete set of change gears to cut most anything in the way of threads.
I'm just lazy that is all. :D I actually find it useful to see all of the different combinations and also to work to a percentage of accuracy when 'close enough' will do.
I used the program to work out what the minimum number of gears I needed to make was to enable me to cut all of the common Imperial and metric threads plus a couple of odd-balls.
