Noted, so with a 3/4" x 24tpi thread case, the measure will be 3/4" on the male part and 23/32" on the female part (ie: .750/24)?jsmithseven said:One such formula is: 0.750 / TPI. In this instance, 0.750 / 11 = 0.0682", so you would incrementally feed in with your compound a total of 0.0682" to create a full depth thread.
mikey
I think I've finally got it. Continuing the 3/4" x 24tpi thread example, a bolt will have a 3/4" O.D. and the nut will have a 23/32" I.D., the major diameter in each part being the same 3/4".
