- Dec 21, 2018
- 2,180
Are you threading away from the chuck?On the lowest rpm its still to fast teting to turn motor off at the right time
Yes ,Are you threading away from the chuck?
Project for the winter spindle bore crankMy 10x22 lathe minimum speed is 100 RPM. It's hard to time the coarser threads, they move so fast! If I'm positioning the tool, especially for metric, I turn the lathe by hand. Especially handy for the situation you are in, with a thread gutter and threading outwards.
I made a spindle bore crank for my mini-lathe. I used it for threading for a while. I rarely use it these days, especially after learning reverse threading. Never made a spindle bore crank for my 10x22 as I feel like I'd use it only a couple times. However, I learned a lot making the crank, so I do recommend doing it.Project for the winter spindle bore crank
Will work until I need material through the bore
I was threading away from the chuck.I made a spindle bore crank for my mini-lathe. I used it for threading for a while. I rarely use it these days, especially after learning reverse threading. Never made a spindle bore crank for my 10x22 as I feel like I'd use it only a couple times. However, I learned a lot making the crank, so I do recommend doing it.
Been there, crashed my mini-lathe once. Bent some gear shafts. After I got replacement parts I tried to press in an 8mm pin and broke my vise. Expensive lesson. Found a machine shop to press the pin since I didn't have an arbor press at the time. As I recall he did it practically gratis for me. Had a cool tour of his shop.I was threading away from the chuck.
I was reversing the motor to run tool back to thread relief . I failed to reverse the motor again to move away from the chuck It did not take but a second foe the tool to crash into the shoulder , ugh
Just enough to shred a few teeth of the change gears
Ulma Doctor here on HMF has offered some services.Been there, crashed my mini-lathe once. Bent some gear shafts. After I got replacement parts I tried to press in an 8mm pin and broke my vise. Expensive lesson. Found a machine shop to press the pin since I didn't have an arbor press at the time. As I recall he did it practically gratis for me. Had a cool tour of his shop.
What are you doing about the gear? Post some pictures with key dimensions and I can design one that you can get printed. I'm away from home, or I'd print it. Should work well enough for you to get your task done.
