Perhaps just a typo?Car engines oft run above 10000 and aircraft around 7500-8000
Cheers Phil
???? I've never owned a OEM car with a redline of 10,000rpm, but the highest performance car was MBZ 320CLK and it redlined at 7,500 IIRC.Perhaps just a typo?Car engines oft run above 10000 and aircraft around 7500-8000
Cheers Phil
It is not a typo, Phil. That was in the early days of internal combustion engines, designs were simple and crude, and materials were nothing like today. Even today, with a common Lycoming or Continental engine in small airplanes, the maximum speed is about 2500 to 2700 rpm. Much of the reason for it is the propeller. If the engine turns faster than that, the propeller tips will start to go supersonic, which causes huge amounts of drag. The cure is a geared output shaft (some actually have run the propellor off the camshaft), but that adds complication, cost, weight, and more things that can fail. The four major attributes of a successful aircraft engine are reliability, reliability, and reliability, followed by light weight.Perhaps just a typo?Car engines oft run above 10000 and aircraft around 7500-8000
Cheers Phil
looks like a strange specialty vertical latheThis being advertised as a ''Metal Lave'', so obviously the seller has no idea what it is either. Any ideas?
Valve adjustment a pain too...Fiat X-19. Pull the engine to set the timing....and just to add to the fun it was common for the distributor hold down to come loose....
Robert
possibly a strange planer???
