This might be helpful to those just getting into using carbide inserts.
ltlvt
H-M Platinum Supporter
Aug 29, 2019
1,265
Found this on Pintrest. Good visual of what the letters mean. I'm not sure about the sizes. I usually just look on my insert holder and re-order what is on the holder.
That is a useful chart.
In fact, there are several charts out there, some with more information, others with less.
Another reference is the book "Introduction to Indexible Tooling for the Metal Lathe" by David.P.Best ISBN 9798753874993
In the time I have had the book, I have actually only referenced it twice as regards insert type so, truth be told, I would just as soon have printed off some of the available online charts, laminated them and saved my money by not buying the book and instead spent it on inserts.
In fact, I find the info in the "Engineers black book" on inserts more useful. Those 25 pages (in the pocket sized book) are more useful to me than the Book by David Best!
So looking at those charts. What is a wiper? I never heard that therm used in reference to cutters.
Not as pretty, but more comprehensive: https://www.carbidedepot.com/formulas-insert-d.htm .
GsT
I've had this link for a while and emailed it to myself to my yahoo address and put it in my Shop file notes on Yahoo mail. this way I can reference the entire chart while in my shop. (I have wifi in my shop) I still get confused when trying to use the chart in this link. what does this mean"
Size (e.g. "CNMG432" / "CCMT32.51")
ANSI Code No.
Inscribed Circle Size
ISO Code No. (metric cutting edge length) by shape code letter of insert
decimal in.
fractional in.
C
D
R
S
T
V
W
0.5​
.0625"​
1/16​
1.2 (5)​
.15625"​
5/32​
S4​
04 (4mm)​
03 (3mm)​
03 (3mm)​
06 (6mm)​
1.5 (6)​
.1875"​
3/16​
04 (4mm)​
05 (5mm)​
04 (4mm)​
04 (4mm)​
08 (8mm)​
08 (8mm)​
S3​
1.8 (7)​
.21875"​
7/32​
05 (5mm)​
06 (6mm)​
05 (5mm)​
05 (5mm)​
09 (9mm)​
09 (9mm)​
03 (3mm)​
2​
.25"​
1/4​
06 (6mm)​
07 (7mm)​
06 (6mm)​
06 (6mm)​
11 (11mm)​
11 (11mm)​
04 (4mm)​
2.5​
.3125"​
5/16​
08 (8mm)​
9mm​
07 (7mm)​
07 (7mm)​
13 (13mm)​
13 (13mm)​
05 (5mm)​
3​
.375"​
3/8​
09 (9mm)​
11 (11mm)​
09 (9mm)​
09 (9mm)​
16 (16mm)​
16 (16mm)​
06 (6mm)​
3.5​
.4375"​
7/16​
11mm​
13mm​
11 (11mm)​
11 (11mm)​
19 (19mm)​
19mm​
7mm​
4​
.5"​
1/2​
12 (12mm)​
15 (15mm)​
12 (12mm)​
12 (12mm)​
22 (22mm)​
22 (22mm)​
08 (8mm)​
4.5​
.5625"​
9/16​
14mm​
17mm​
14 (14mm)​
14 (14mm)​
24mm​
24mm​
9mm​
5​
.625"​
5/8​
16 (16mm)​
19 (9mm)​
15 (15mm)​
15 (15mm)​
27 (27mm)​
27 (27mm)​
10 (10mm)​
5.5​
.6875"​
11/16​
17mm​
21mm​
17 (17mm)​
17 (17mm)​
30mm​
30mm​
11mm​
6​
.75"​
3/4​
19 (19mm)​
23 (23mm)​
19 (19mm)​
19 (19mm)​
33 (33mm)​
33 (33mm)​
13 (13mm)​
6.5​
.8125"​
13/16​
7​
.875"​
7/8​
22 (22mm)​
27 (27mm)​
22 (22mm)​
22 (22mm)​
38 (38mm)​
38 (38mm)​
15 (15mm)​
8​
1"​
1​
25 (25mm)​
31 (31mm)​
25 (25mm)​
25 (25mm)​
44 (44mm)​
44 (44mm)​
17 (17mm)​
10​
1.25"​
1-1/4​
32 (32mm)​
38mm​
31 (31mm)​
31 (31mm)​
54 (54mm)​
54 (54mm)​
21 (21mm)​
1.26"​
That is interesting. I have been grinding a sort of a wiper into my HSS lathe tools for a long and never knew it was a real thing.
ANSI Code No.
decimal in.
fractional in.
C
D
R
S
T
V
W
0.5​
.0625"​
1/16​
1.2 (5)​
.15625"​
5/32​
S4​
04 (4mm)​
03 (3mm)​
03 (3mm)​
06 (6mm)​
1.5 (6)​
.1875"​
3/16​
04 (4mm)​
05 (5mm)​
04 (4mm)​
04 (4mm)​
08 (8mm)​
08 (8mm)​
S3​
1.8 (7)​
.21875"​
7/32​
05 (5mm)​
06 (6mm)​
05 (5mm)​
05 (5mm)​
09 (9mm)​
09 (9mm)​
03 (3mm)​
2​
.25"​
1/4​
06 (6mm)​
07 (7mm)​
06 (6mm)​
06 (6mm)​
11 (11mm)​
11 (11mm)​
04 (4mm)​
2.5​
.3125"​
5/16​
08 (8mm)​
9mm​
07 (7mm)​
07 (7mm)​
13 (13mm)​
13 (13mm)​
05 (5mm)​
3​
.375"​
3/8​
09 (9mm)​
11 (11mm)​
09 (9mm)​
09 (9mm)​
16 (16mm)​
16 (16mm)​
06 (6mm)​
3.5​
.4375"​
7/16​
11mm​
13mm​
11 (11mm)​
11 (11mm)​
19 (19mm)​
19mm​
7mm​
4​
.5"​
1/2​
12 (12mm)​
15 (15mm)​
12 (12mm)​
12 (12mm)​
22 (22mm)​
22 (22mm)​
08 (8mm)​
4.5​
.5625"​
9/16​
14mm​
17mm​
14 (14mm)​
14 (14mm)​
24mm​
24mm​
9mm​
5​
.625"​
5/8​
16 (16mm)​
19 (9mm)​
15 (15mm)​
15 (15mm)​
27 (27mm)​
27 (27mm)​
10 (10mm)​
5.5​
.6875"​
11/16​
17mm​
21mm​
17 (17mm)​
17 (17mm)​
30mm​
30mm​
11mm​
6​
.75"​
3/4​
19 (19mm)​
23 (23mm)​
19 (19mm)​
19 (19mm)​
33 (33mm)​
33 (33mm)​
13 (13mm)​
6.5​
.8125"​
13/16​
7​
.875"​
7/8​
22 (22mm)​
27 (27mm)​
22 (22mm)​
22 (22mm)​
38 (38mm)​
38 (38mm)​
15 (15mm)​
8​
1"​
1​
25 (25mm)​
31 (31mm)​
25 (25mm)​
25 (25mm)​
44 (44mm)​
44 (44mm)​
17 (17mm)​
10​
1.25"​
1-1/4​
32 (32mm)​
38mm​
31 (31mm)​
31 (31mm)​
54 (54mm)​
54 (54mm)​
21 (21mm)​
1.26"​
Which part is unclear? There are several ways of specifying the size of an insert, the two common ones are cutting edge length (blech!) and inscribed circle (IC). I favor IC because it's easy to understand, and pretty easy to eyeball the difference if you stay away from the weirdo sizes. For instance, most of my inserts are either 3/8" or 1/2" IC - regardless of shape. IC is the biggest circle that can fit within the outline of the insert. So it's pretty easy to tell the difference between those two. In the examples given (CNMG432" / "CCMT32.51) the first has a "4" and would be a 1/2" IC, the second is a "3" and would have a 3/8" IC. Does that make sense?
The ISO code is the cutting edge length, so even for an insert with the same IC, the ISO designation can be different, depending on the shape. I consider it tedious and must refer to a chart like that above if forced to do so.
GsT
GsT
So what you are essentially saying is that the example nomenclature is based upon a base of multiples of 1/8"?
Yes, for all the ANSI (IC) designations, not just the example. The ISO spec is edge length in mm.
GsT
