- Jul 2, 2014
- 7,594
How about asking friends and neighbors for help?
The plywood sounds like a good idea. you will want to secure it to the crate or pallet so it stays under the load. If it is larger than the base, screw a coupl3e of cleats to the plywood and screw the cleats to the crate.. I just use the planks on the stairs.@RJSakowski
Thanks for your reply! I was wondering how to do the rollers and turn corners. The pallet bottom isn't flat, how do you avoid getting stuck in between the boards?
Big 3' pallet looks like
| ___________________________________ |
|______| |_______| about 1/2" thick board
28" Crate bottom is more like
| _________ ____________ |
|____| |____| |_____| about 1.5" thick height
The forum is not preserving spacing of my ascii art.
Guess one needs to fab a flat base. Have some 3/4" plywood for a base.
For the 2x8's you plank the whole run? Or?
I'll check on the come-along that's floating about in the garage. No idea how long it is. Err, not there. Probably in storage. Have to make a visit today.
Thanks for the practical suggestions! A boat winch sounds interesting as well.
Maybe I'll figure out a way to pull the doorway. It's so close...
Well, the nice man dropped off the pallet at the top of the driveway, exactly where I told him to. I thought I'd be able to move it. Turns out, my strength isn't what it used to be. It's possible to lift up the crate onto either a hydraulic lift cart or a hand truck using my engine hoist.
It was kind of a comedy of errors, but fortunately nothing was broken, nor any body parts harmed.
