- Apr 1, 2014
- 13
The bed section is for use with a special 90mm centre height dividing head. The tailstock i have uses morse nr 0 so the tip is easily replaced. If you look into the drawbar end of your millhead you will se the stud that prevents the collet from rotating.
Thanks so much for the photos and the description. I guess they discontinued use of the collets on the drawbar side of the millhead as my series 13 from the 70's does not have a taper or the stud.
Your tailstock will work with my dividing head, but I don't know if it's feasable to have it shipped from Norway to Texas. Do you have an idea of what you would want for it?
thanks,
Dave
