so how would one go about testing the "flatness" of a home hobby granite sink cutout reference plate or a tempered glass plate / granite sink pancake layering plate for true flatness?
ideas:
a) tram "flat" then test concentric circles?
1. an lever could be used to amplify the sensitivity of a dial indicator
2. glass is very smooth, if not flat..., tramming might work well with amplified sensitivity
b) ink another "flat" and compare the touch patterns under different orientations. (reverse, iterative
1. would not give clear indication of which direction the test surface is not true
2. cant scrape glass flat
3. hard to see ink on granite
4. relies on flatness of second flat however as a test of uniformity, would be useful.
