I am not sure how I am going to get another 6 or 8 wires through my cable chains...
Oh, definitely not. It's not a permanent setup. At least, it won't be for me anyway
Route the wires somewhere, somehow, and after the shaping operation is done, save_config, pull that stuff off and throw it in a drawer until next time. I'm just going to temporarily route the wires out through the skirts, and in through the front door.
Unless im mistaken, when you run the shaper_calibrate command, it goes to a specified point on the bed, like x150, y150, z100, and just shakes and vibrates awhile. It will create a section on your config file with the parameters. Kinda like your bed mesh does. After it finishes the shaper_calibrate process, just save the data with save_config, then shut down and remove all the adxl345 hardware.
restart the printer, and your good-2-go until the next time you change something that messes up the resonance, like switch to a different hotend or something. I'm stil not up on the macros yet, like, will I need a command in the print start macro to load the input shaper profile, or something?
Of course, I could be wrong about some or all of this. I'm still in academic mode, searching and reading. I'll learn more when i get to the "doing" part of it.
