- May 7, 2023
- 2,419
The thought crossed my mind even before seeing this.
If you inhaled just the right amount of propane and oxygen mix, would it be possible to blow yourself up if you breathed it onto a lighter?
A good start?What do you call a bus full of lawyers going off a cliff with 1 empty seat? A cryin shame....
Not sure I even want to admit this…..I don't know. Breathing propane might give a high. I was surprised to learn that inhaled isopropyl alcohol was once used as a general anesthetic. But there is probably a fine dosage line between high and dead.
lethargy, death, and life during certain times of the month.Also:
"excessive use of this bed can cause blood clots, insomnia, lethargy and death"...
And THAT is where the "problem" lies.I don't know. Breathing propane might give a high. I was surprised to learn that inhaled isopropyl alcohol was once used as a general anesthetic. But there is probably a fine dosage line between high and dead.
the labels are carcinogenic by designI love California’s Prop 65 labels on everything. Almost seems like everything but what can cause cancer has the label!
