Finished cleaning the headstock parts today. Found another broken part. The half of the spindle engagement clutch that attaches to the pulley gear is broken. One more thing to have to buy. Also found that the bearing surface on the spindle for the pulley gear isn't as smooth as I wish it were. Trying to decide whether to just live with it for the time being or take it to a machine shop to have it cleaned up and polished. It's not "shot" and would be fine for quite a while, but the lathe would probably run quieter if I had it polished and replaced the bushing.
I pressed out all the bushings in the QCGB. I'll order replacements on Friday.
As you can see, I have parts in small containers all over the cabinet. Next up is cleaning the Reeves drive and motor, then the bed and cabinet top.
I bought primer and paint this week, but realized today that I'm not going to have any more days this year that will be warm enough to paint. My shop is heated only by a wood-burning stove, and I don't want to be painting with enamel in an enclosed shop with a fire going! I guess I'll take the paints back (they were stock items at Tractor Supply) and use the money on parts, like the broken clutch ring. I'll worry about paint after I get moved next year and get set up in my new digs. So, for now, once I finish cleaning and get all the parts I need, I'll start reassembly. Looking forward to it.
I also have three shafts to replace. Like I mentioned before, I found a lathe I can use, a SB 9A, that belonged to the late husband of a friend. However, when I went to look at it, I could see it needs some serious cleaning, maintenance, and tune-up. I offered to buy it for a reasonable price, but she isn't ready to sell. I made her a proposition, that if she would let me take the lathe and tooling to my shop, I would clean it and tune it up for her, which would make the resale value higher for whenever she was ready to sell it (I wouldn't be buying it). The benefit to me would be the use of it for a few weeks to do repair work on my lathe. Not sure she's going to go for it. Sometimes widows are funny about their husband's things. I may just have to re-install the shafts as they are and get my lathe operational, then make the shafts and replace them as I go.
So far, items in need of repair/replacement are:
Clutch gear*
Compound gear*
Half-nuts
Tumbler gear (MCL-404)**
Tumbler gear (MCL-271)*
All bushings in the QCGB*
Handwheel shaft bushings in the apron*
Compound gear shaft
Handwheel shaft
Worm gear bushing*
Tumbler shifter shaft
Cross feed screw and nut
Compound feed nut
spindle clutch ring
Optional things (for now) are:
Cleaning up and polishing the worm gear bearing surface
Cleaning up and polishing the pulley gear bearing surface on the spindle
* indicates located and/or ordered
** indicates located, ordered, and paid for
