- Feb 28, 2019
- 132
i have a Potter and Johnston 24 inch shaper. Is really amazing the features this 1890-1910 machine has. Sometime in its life a large over center clutch and hand lever were added, and then a 4 speed gear box, running off a 3hp 480v motor. it now has a 230v 1ph 5hp motor. it has a vernier scaled rotating table, with a second table top that has a vernier scaled angle plate built into it. Obviously an adjustable throw traversing mechanism, power Z both directions. power down feed with adjustable travel. rotating head can power up if its reversed, and with the optional rotating feed it can cut a radius, and if that radius is large enough it can cut a circular hole, as the head can rotate 360 degrees, if its set to only stroke outside the frame. All i need to do is locktite the traversing thread shaft nuts so they dont fall into the gearset, and put belts on it.
