- May 4, 2015
- 3,574
You should be able to match the pulley , grind your bit and fit it to the pulley you have the spacing set by the width of the pulley. It's not a job you have to get too super tight tolerances. Even your diameters can be changed if you want slower and faster speeds. I wouldn't make the job harder then it is , the only thing I'd suggest is if your chuck has more then a few thou run out I'd use an arbor and centers to keep run out down. Helps keep vibration down on the drive . Your pulleys can be made separate also then use one key and 2 set screws or 2 on each pulley . Just what I'd do but think it out you can do it.
