Enter ... Stepper motors and CNC controllers.
I'm going to use the Mach3 software which needs a dedicated PC for it.
The power supplies and stepper drivers were bought but the rest have just been lying around for years.
About halfway wiring everything together, took me quite a while with lots of pauses, trying to figure out what goes where and why.
Finished all the wiring and it should pretty much be a CNC controller by now.
3 fans in the front suck in air through the filters and 2 fans in the back throws it back out.
This hopefully keeps the box slightly pressurized so it doesn't suck in dust through small leaks in the box.
Prototyping up some motor mounts I started with paper templates, later moving on to 3D printed templates of my designs.
Rather find flaws on a easily reprintable piece than a piece of metal I've spent all day on.
Lots of hours later .. Bugs ironed out and remade everything in mild steel.
Left is Z and has a torquier(is that even a word?) motor, right is the Y axis.
Simpler holder for the X axis. Z and Y became overcomplicated due to my lack of experience designing things like these.
Still mostly using old scrap to make these things. Got a few of these old pipe lids that I managed to use up making motor plates.
Voilá, one CNC almost ready to run!
Feeds perfectly now. You can mill "as normal" by just jogging it with a wireless keyboard or you can send it a full program to do more advanced manouvers.
Keep in mind it's still using the original screws with tons of backlash.
The software can compensate for that backlash up to a point but I'm not expecting thous here.
Screen on the wall can show both the hidden raspberry and the CNC computer, just select input depending on what you're doing.
The wireless keyboard on the worktable is to the CNC.
I also dabble in making youtube videos so here's a summarization of the project up to this point:
