That worked very well.
The assembly now slides easily into the tube.
Next job was making 9 identical lengths of 12mm x 25mm x 90mm for various brackets.
Rather than filing my angle grinder rough cuts to size I decided to try and face them.
I clamped 3 lengths together with the "G" clamp then set them up in the 4 jaw and faced the ends.
The top 4 have already been done in this pic and these three have been faced at one end.
Held with the clamp then set in the 4 jaw very firmly.
The middle piece is the length to face down to.
Yes, I know that a lot of hanging out but I took it gently with slow feed and shallow cuts and it all worked fine.
Even after the event I find it unbelievable the two outside lengths didnt shift out of position.
You wont know till you try.
