They look awesome, but as you say, will need the point in the middle.
The image begs the question as to how those two came to be without the needed point.
I have seen drill bits intended (I think) for woodwork that look a bit like that, and I have some left over from one of those cheap hardware store sets. We do know that those which come with a point that is not just a point, but looks like the sharp end of a wood screw are definitely for wood, and will pull themselves through pretty well when turned slow with a auger.
My thinking is that while the cloth trick is intriguing, it still lacks the centre guide that disappears when the drill breaks through. Having a centre point guided drill sharpened like yours, with a backing under the sheet metal that can have the drill maintain the centre line, is what makes sense to me. I also think that my recipe of clamping between two bits of aluminium is pretty uncompromising, and the hole ends up centred where the pilot hole was put, without any "last turn re-location" effect.
I would never put you to new activities in making tutorial videos, but maybe you have a tip, or a link to one where sharpening like that is done?
