Oh I learn't plenty from building around 12 recumbents, that's not to say they will suit you! Lets see, First was no more than 42 degrees backrest angle, sore necks proliferate at anything more, but that could be due to my cervical spondylosis. No more than two or three degrees caster or camber, any more will scrub out the tyres pretty quick. If you use tie rod ends, use a left hand thread on one and a right hand thread on the other. Just makes adjustment easier. Steering type is a personal choice, but I found tank/lever steering the best, under seat steering works ok too, but not as well as tank. Your need the crank around 150mm higher than where the seat meets the backrest, anything more or less makes it a little uncomfortable. Try out different squab angles to suit your bum, you also need lumbar support or your back will suffer. It's also a good idea to have the backrest in two parts with a gap in between, so the seat back doesn't rub against your vertebrae, flat seat backs are terrible. If you are young, you will need either a really big chain ring or intermediate gearing to raise the gearing. Pedalling cadence should be slower than on a diamond frame, pedalling fast on a recumbent will send you swerving all over the place. Back brakes are useless, don't bother with them. Place the seat as near to the rear wheel as you can get, the further the seat is away from the rear wheel, the more rear wheel slip you will get. Of course that means having a longish boom, the further back the seat the longer the boom will need to be because of the positioning of the cross beam. Try getting out of the frame with the crossbeam leading to the front wheels at different positions. Too far forward and you won't be able to get out of the thing without jamming on the brakes and allowing the momentum to throw you forward and out, too close to the seat will put more weight on the front wheels and less on the back leading to rear wheel. Slip.. You need Ackerman, without it it will understeer and scrub out tyres. Square tube is stronger than round, particularly around joins. Design something that uses as little metal as possible, it all adds up to weight. Two wheelers are a lot faster than trikes, tadpole trikes are stable, two wheels at the back are unstable and will tip easily. You don't need padding on the backrest if it is shaped to your back, but padding is nice under your bum. Delrin makes for good bearings in the kingpins and steering bars because it is light and seems to wear forever. Same with chain idlers, just make sure the chain idlers run in high speed bearings and the chain run is as straight as you can get it.Really cool. On my too long "I wanna" list. Any lessons to pass on about steering geometry?
Thats about it, keeping in mind, everyone is different what suits me may not suit anyone else.
I've attached some build pictures that may help, along with a couple of earlier builds. The two wheeler was never finished, fell off and gashed my head and leg, the wife then convinced me to concentrate on trikes. I followed the two wheeler up with the trike minus rear suspension. It worked fine, but had plenty of wheel slip due to seat being too far forward and crossbeam too far back.
78134239_2526587860934578_643996282649575424_nshock on adjusting plate.jpg152.9 KB · Views: 6
78134239_2526587860934578_643996282649575424_nshock on adjusting plate.jpg152.9 KB · Views: 2
