The Eifel Plierench...what most people have been missing!
And now a correction! What I was calling the normal jaw is actually a specialized one b/c of its layout. They call it the Universal jaw. It does not have a typical series of grooves for gripping, but rather a starburst patters. The (terrible picture of the) attached page explains it: And this actually is the one I use the most:
The second picture is the March 1959 set I have that I restored to factory new condition. This is one of the ones I mentioned where the jaws that came with it a thinner then the Flash jaws. It still works fine though. And I do like the red handle grips, but, really, since the nature of this tool means there is no wear and tear on your hand, they are redundant.
Picked up one of the 12" Knipex pliers with a few other nice tools dirt cheap form some wealthy woman cleaning out her condo garage in town. Way nicer tool than my Channellocks, although I do love my big Channellocks when they are required. Guess I will wait for the fierce bidding to calm down before looking for this new toy. ;) Mike
Knipex is a great tool line. This is the way tools should be made IMHO.
Congrats on getting the new toys! Enjoy exploring how to use them.
I also remembered I have used mine to pull out broken off drill bits rather easily.
I learned from Scoutcrafter (youtube tool restorer) that a mirror-like finish will keep tools highly resistant to rusting. So if you guys are going to clean yours up, the easiest way I know of is first using a bench grinder setup with a wire wheel. Then following that with a nylon fiber polishing/buffing wheel really makes a HUGE difference in the finish.
When you use one of those fiber wheels the first time, you find yourself tempted to use it on all your tools b/c the difference is that dramatic. When I got mine they were only 2.99 each, but now they are up to 10.00 (if you shop around) with a lot of them listed at 15.00-20.00. The wheels come in different grits just like sandpaper and I think the last one I got was medium.
Looking back at the restored plierench I posted with the red handles, this is the technique I used. Very fast restoration and you can see the results are dramatic.
The restored Flash I posted was before I knew of the fiber wheels, and I used a wire wheel, sanding it on a small belt sander, and then a buffing wheel with three different compounds. It took quite a bit longer.
Doesn’t need cleanup. It’s a black oxide finish that looks perfect as it is. I’m assuming June of ‘55 from what I see stamped.
Rick “but the canvas pouch is grotty” Denney
Mine came today. I was rather surprised that the jaws did not line up perfectly. The wrench does not seem to be bent, but there is also a little more slop than I expected.
As a side note, my wrench has a very distinctive blue hue to it, very similar to what was/is on my old Remington 870 shotgun. I am thinking that the originals were possibly blued from the factory.
PXL_20221031_175441308.jpgPXL_20221031_175409977.jpgPXL_20221031_175343260.jpgPXL_20221031_175335474.jpgPXL_20221031_172825840.jpg
