On mine, the confusing thing (not the LCD one btw) was that the bolt circle took start-angle, end-angle, center, and # of bolts. The only way I could get it to give me the right answer was to put in 1 extra bolt and get it to start/end at 0 degrees. Otherwise the numbers were wrong.I have found the features on this model to be very easy to use, more of a learning curve than any difficulty with the features. For the bolt circle I made a pattern on my indexing head with known dimensions and then used the DRO to check the coordinates and they lined up really well to what I had made on the indexing head.
I've never worked with these scales before. Can someone tell me whether this red plastic spacer is just there for shipping purpose?
I'm not sure if we still do the you suck thing. If we do, you sir suck. I'm 2 days out from receiving a similar dro I ordered at the end of the year. I learned that adds abt 2 weeks to the process. Anyhow, I'm jealous and I look forward to seeing your progress and thoughts on the equipment and manual.
