Reassemble in reverse order, with a couple of tips.
1: When remounting the Saddle after cleaning, keep the wipers loose until you have the retaining plates and gibs remounted and adjusted. The wipers provide an amazing amount of resistance to free movement!
2: Have an assistant to help reattach the apron! One person will have to hold it in position against the placement pins, while the other person gets the 4 socket screws started.
3: When replacing the lead screw and feed rod, check the alignment of the holes for the roll pins!! My lead screw roll pin is a one-way option. Reassembling after sunset, I got it seated most of the way before realizing the other side was about 30° off. Had to use a smaller roll pin punch and side cutters to pull out the partially driven pin, then rotate the lead screw 180° for the holes to align properly.
4: Reassembly of the compound showed that the gib, the handwheel bracket, the handwheel, spanner nut, and set screws, all have an effect on drag AND backlash! While it took some fidgeting to get the drag and backlash balanced, judging from the index ring on the compound the backlash is going to be less than 0.003". I'll verify this with a test indicator once the teardown/cleaning/reassembly is completed.
My apologies for the discombobulated order of the photos.
My partner and "apprentice" rolled his ankle prior to this project, so we will be doing it again in the not too distant future. At that time we'll conduct a video of the operations in the correct order.
