I use a tenth gauge all the time. Probably have half a dozen test indicators and acouple plunger style. Also have some .0005.
I understand in most instances you don’t need tenths but the closer you get it the more room for error on your end with machining.
Surface grinding I use a tenths indicator that’s it. The more I think of it I have more tenths than thousandths indicators and rarely use the thou. ones. Usually for rough alignment of a part
