- Sep 29, 2014
- 2,102
I may give you some insight as to what you might expect in the real world, if you do not go directly from school to working for an aerospace/automotive/pharma contractor.
If your first employer is a job shop then you will be required to do exactly that, whatever is needed.
You may have to deburr 1000's of parts or just run a saw for days at a time, degunk the coolant sumps and so on.
It will take a bit of time before they just give you a drawing and work order because they know that you can make the parts without supervision. At that point you will become entirely to valuable running parts and will no longer have to do the second operations and other simple tasks.
Good Luck
Good Luck
