Hi guys.
I have a customer that I quite often have to make a bush that is welded onto a flange. The bore is taper and there must be a 4mm keyway in there.
My question is this. Is there a better way to make a keyway on a taper bore than the way I do it? I have to broach at the same angle of the bore,so what I do is use my compound with a HSS toolbit to push out the material to get to depth. But I do not like putting so much pressure on the leadscrew of the compound,I don't think it is good for it. Here is a pic of how I do it. Hope it is clear enough.
Another question is,if I use my dividing head and put it in the vertical position at the angle of the bore of the bush, or just tilt the mill head at angle and clamp the part down.The angle is about 6 degrees, can you use the quil of the milling/drilling machine with a 4mm toolbit to broach the keyway?
If there is a better way out there to do this tipe of work irrespective of the angle of the taper, wich will work better than I am doing now that will save my compound from the torture I am putting it through, PLEASE advise on how to do it. Thanks for reading.
