- Jan 4, 2021
- 3,275
Don’t have a SB Heavy 10, but . . .i'm going to buy a tangential tool holder from Eccentric Engerining. i am confused as to what size to buy. my lathe is a south bend heavy 10. i use a aloris A tool post. will be using 5/16 or 3/8 tool bits. i contacted them, and didn't understand their response. (rather than say that i am dumb, i use the excuse that i am a old man) any help as to what size to buy??
Per the Tool Selection Page:
And using the 8mm Tool Holder as sn example:
In order to be able to use this Tool Holder, the distance from the centerline of the spindle to the bottom of your tool post holder (where the Tool Holder will sit) must be at least 8mm:
Select the largest Tool Holder that suits your center height/Aloris holder dimension and which will fit into the Aloris holder:
Sorry, had to relocate to my laptop (playing with photos on the phone is a pain).
Here is my 8mm Tool Holder in a 0XA QCTP with a 250-001 holder (I have a 7 x 16 Mini-Lathe):
And here is the distance between the center and the bottom of the 250-001 holder:
The distance is 12mm, but the largest Tool Holder that will work is the 8mm (a 0XA/250-001 will just hold a 12mm shank, but it's tight).
If you can hold a 15mm+ shank in your Aloris AXA holder and the bottom of the holder is at least 12mm below your center height, then go with that one.
The 8mm, 10mm & 12mm Tool Holders accept 1/4" bits; the 16mm & 20mm Tool Holders use 5/16" bits.
I hope this is clear; if not, give me a shout.
