- Feb 2, 2013
- 3,962
I received a Vevor 1340 wood lathe for Christmas 2022 and started playing with it....
One of the shortcomings of the lathe is the inability to drill from the tailstock.
I took it upon myself to rectify that situation.
I purchased an inexpensive 1/2" capacity Jacobs' Keyless Drill Chuck .
it came tapped with a 1/2"-20 tpi female thread
I found a 10" piece of 304 Stainless M18x2.5 all-thread and a jam nut on ebay .
turned one end to 10MM to accept a handwheel
I turned the opposing end to .500"
and single pointed the threads for 1/2"-20 tpi very close tolerance fit
i removed the live center from the tailstock and installed the drill chuck
the full extension is approximately 5-1/4" with the jam nut
the next project will be turning a handwheel to utilize the retrofit
stay tuned if you dare!
