Posting this here because I do gun work on my lathe. Am trying other ways to chamber, do it through the headstock now, and was aligning my tailstock. While I was at it decided to tear it apart and clean it up. American Turnmaster 13 X 40, 2 speed motor, Aloris toolpost, 2 axis Mitutoyo DRO. After reassembling it, much easier to adjust, laterally was a snap, heighth is .002 too high. Believe I will put it on the surface grinder and take 2 off. By the way I use a Torque wrench to torque the hold down bolt so that it is repeatable. It always turned a slight taper between centers, which is part of the reason I chamber through the headstock, with an outboard spider. Have a dial indicator rigged up on the tailstock quill for depth and believe I will make a plate to span across the bed and put an indicator on it to bring the tailstock back in position. Maybe just a stop. Any thoughts?
