- Nov 23, 2017
- 1,191
Run a big beef steak through it with your son watching, he'll figure it out really quick after that....
I don't think there is anything wrong with safety warnings like making the danger zones etc. Just something to help remind you to THINK.
Don't know if any of you have ever seen the Saw-Stop system, but we had one of these in the carpenter shop at the company I worked for. I got to see it demonstrated a couple of times. It's pretty impressive to see. I know this is probably beyond the means of a lot of hobbiests, but if I remember correctly, the saw itself wasn't much more expensive than any other good quality commercial table saw. Anyway, just thought it may be interesting to some.
Ted
There's an override switch on the control panel, meant only for occasional use (wet wood comes to mind). If all you cut is aluminum, then the SawStop is not what you'd want to spend your money on.This is cool but how do you cut aluminum with the stop saw.....?
The only reason I have a table saw is for cutting aluminum.....
