- Mar 3, 2020
- 195
Hello,
I am contemplating making a set of T-nuts for a new-to-me rotary table with a 3/4" wide slot with a 1/2" wide opening.
I have T-nuts that I made in the past which are 0.685" wide. I was contemplating making the new nuts ~0.730" for the 0.750" slot. Admittedly I am not sure how much clearance is in manufactured nuts, and am wondering if I should just use the 0.685" nuts. They just don't reach as far to the edges of the slots. However, given that the nuts compress the work against the t-slot lips rather than pull up on the lips (only the force of machining does so), these are probably just fine, no need for new nuts.
Is that logical - use the slightly narrower nuts?
P.S. Anyone have a commercial Te-Co nut for 3/4" slot and know the width?
Thanks!
Thanks!
