Contact the source of the material and ask for the suggested preferred solder.
Get correct solder as well as correct flux.
Solder requires absolute cleanliness to work properly and the flux is cleaner as well.
Assume it is black and sooty so clean it up.
Use very fine steel wool and light pressure to get it shiny clean.
If you made it red hot you may have altered metal chemistry so a light filing of mating surfaces may be needed.
In that case set dry paper face up on table and wet with just water and lightly drag the part across to make faces fresh.
Propane torch is more heat than needed and a Wagner paint removal heat gun is A PERFECT tool as it puts out a lot of heat in right range.
Sent from my SAMSUNG-SM-G930A using Tapatalk
