- Jun 7, 2019
- 416
It’s quite old printers black ink. I’ll try ammonia, acetone and alcohol. I’d love it to be clean. But stained won’t hurt its function. Thanks for the suggestions. If anyone wants a drawing I’ll post it.
Can you please cite that information? I looked, albeit quickly, and the only things that came up say, Acetone is perfectly safe to use on Granite. Though I want to be sure as I use it for cleaning my surface plate.Acetone is petroleum type carbon chains, and degrades the crystal boundaries in the granite.
Did you use the 3 point support for your plate?
I find it hard to believe that's actually necessary but it is recommend.
I'll make a recommendation. Tempered hardboard (masonite). If you can find the smooth on both sides all the better. It doesn't pick up stuff from being soft, is light and durable. Just put a edge on it to keep it on. My 2 cents.Hi Larry
Yes it is sitting on the the feet points installed by starrett. There are additional horizontal steel tubes front to back providing the support points. These 3 feet are the only contact points. The vertical corners are almost touching the granite and are just to make sure it can’t get away. Not that 500 lb rocks tend to hop around much. I did a good bit of research before building the stand. I have 2 smaller plates. They are also sitting on 3 point hard rubber feet. The stand has leveling feet on the bottom of the legs. After it sits a few more days I’ll get out the Starrett 199z master precision level and level it up. Need to make a wood cover soon.
Here’s a link to the standard.
