Thanks for the advice. I'll try the degreaser. Ok, I PROMISE, I will not drill into this and use it as a machine base. What was I thinking?!Great find Bryan.
It is absolutely restorable. I would try removing the coating by spraying with Easy-Off Heavy Duty BBQ Grill Cleaner.
Rinse & repeat as required.
One issue with using CI for precision surface plates is that any ding raises an annulus. Granite may chip, but no raised annulus.
That means you have to be even more careful with CI. If you get a ding, you have to stone it. What?
Clean it up and survey it for flatness. I don't know if you have a large enough granite, but I'm hoping you have access to one. Maybe, as is, it's flat enough for your desires at this time.
If you drill holes in it to mount a Chinese arbor press (or the like), I will shed a tear.
Stoning won't be an issue and have done this before to remove burrs and raised sections you describe. I can feel a few raised areas around some pits and dings, so it will require some love and attention.One issue with using CI for precision surface plates is that any ding raises an annulus. Granite may chip, but no raised annulus.
