Surface Grinder Wheel Balancing Fixture
I don’t know the process but this method seems to work.
I elevated the device on the three point brass screws.
Then I used my surface plate and a height gauge to get the ground stock at the same height.
I then used my 6” Starrett level to get squared away.
I mounted a wheel on the arbor and checked the balance.
It repeats! I found the same results over and over, marked in red as the light spot.
I was going to ask about that. I'm wondering if you put a plate in the middle bottom, then get a bullseye type bubble level. While I realize the bubble level may not be accurate to the .0005 per 12" it still should be very good.. just an idea.
Check my results. I just used the six inch, I have a 12” Starrett and one of those super fussy .0005” in one mile levels :)
Back in the day when at the engine shop they balanced their wheels similar but the base was pairs of overlapping rollers, imagine 2 wheel bearings mounted o opposite sides of the sides.
They are spaced so they will support the shaft between them.
Say you have a pair of 1 inch od bearings.
You mount them via bolts drilled maybe 0.75 apart.
Does not need to be level as the shaft rolls in place.
Sent from my SM-G781V using Tapatalk
That sounds like a good choice.
It did work ok though. I was able to balance two wheels and noticed a marked improvement In surface finish.
Those are roller balancers, sometimes referred to as dynamic, though that implies the unit being balanced is spun under power, like a crankshaft machine.
Rollers use large narrowly crowned wheels, 4 of identical diameter, and very small (proportionally speaking) single row ball bearings, for lowest possible friction & easiest centerline alignment. Commercially, they appear to be hardened, against indentation and friction.
The A-shaped frames are usually cast, 1 foot pad (may) be a jack screw for stability, a pair of sturdy rods slide in bored holes, also for alignment. Level isn't requirement, but can improve results. I've not seen one sized suitably for wheels less than 10"-12".
Use of drill/ reamer blanks for rails turns out easier than knife edges, and less prone to damage. Many have a bullseye bubble level for initial setup, shortening tedious indicating. Three screws mean only two need manipulation.
