- Mar 26, 2018
- 8,666
Pinch me, I did it right!
For three days now I’ve been struggling with how to cut the taper. Part of that time was to determine the angle I was to cut.
I have a B&S Micromaster surface grinder. I found a schematic that showed the taper at 3” per foot.
I deduced this to be a 7.125 degree angle.
I made a jig to set up the compound.
I cut the taper to hold a wheel adapter for the balancing fixture, yet to be built. This is the hard part, the rest is easy for me.
I could not be more pleased. The adapters lock up perfectly.
This is big boy stuff!
Now I can finish the arbor by threading for the locking nut.
Ca-Lem is. my inspiration.
Edit, I should add, the random holes in the angle tool was my failed attempt to use my mill dro to cut the tool. I failed to consider the cutter radius and made a big mess of it.
I used my Jo Jo blocks and my compound sine to set the angle and ground it in on the SG.
Oh, first time to turn between centers = slick as can be, simple to set up too.
I’m telling you, this is adult entertainment. For me anyway.
